GA16DE dans wikipédia (rupteur 7300trs)
Messagepar Escandre 85 » Mar 18 FĂ©v 2014 19:08
Il y a un commentaire sur le rupteur (en rouge) :
The GA16DE is a very popular engine from Nissan. It is found in many Nissan models, like the Nissan Sunny (N14 and B14), the Nissan Almera (N15), and the Nissan Primera (P10, injection models, P11 & P11-144) 100NX. It is very similar to the GA14DE, aside from a larger displacement.
The GA16DE is a robust, reliable engine with a displacement of 1596cc. In North America it was used in the 1991-1999 Sentra, 200SX, and NX models. Later-model GA16DE (95-99) engines had more aggressive cams, straighter intake ports and performed slightly better. Despite being designed for economy, GA16DE-powered cars are also somewhat popular in tuning circles, due to a smooth powerband and good response to bolt-on modifications. The factory redline is set to 6900rpms, with aftermarket tuning increasing it to 7300.
In the UK it was featured in the first 3 incarnations of the Nissan Primera featuring good fuel economy and, despite its low displacement, decent performance thanks to its Twin cams and 16 valve configuration. Power (based on the 96-99 1.6 primera) is 98 bhp (73 kW) @ 6000 rpm.
In Australia it was used in the Nissan Pulsar N14 and N15.
A GA16DE was also released with the NVCS (Nissan Variable Cam [timing] System) solenoid, it carries the plastic rocker black valve cover with a different throttle body design which produced 115 hp (85 kW) @6400 rpm and 110 lb·ft (146 Nm) @4400 rpm. The solenoid "opens" completely at 4,000 rpm.
Quelqu'un connait ?
[NX-POWER]Escandre 85
Voiture: Prim P10 GA16DE
Re: GA16DE dans wikipédia (rupteur 7300trs)
Messagepar matmax » Mer 19 FĂ©v 2014 22:37
connait quoi?
il disait qu avec un reprog , il ont déplacer le rupteur as 7300 !!
mais quel utilité sachant qu après 6000 , il y as déjà plus rien !!
Messagepar V8 » Jeu 20 FĂ©v 2014 00:03
Pas d'accord Mat :wink:
sur la bleue je montais au rupteur sans soucis et sans chute de courbe....du coup quand la 3 passait ça repartait mieux aussi.
Par contre je ruptais Ă  7200 sans modifs ??!! :icon_exclaim:
je dois avoir une vidéo qui traine d'ailleurs
Messagepar matmax » Jeu 20 FĂ©v 2014 00:06
la carbu entre 7000 et 7100 !
mouais moi je sens bien que ca s essouffle après 6000-6500 !
Messagepar Escandre 85 » Jeu 20 FĂ©v 2014 00:11
Ben sur la mienne pas du tout . Mais je ne dis pas qu'elle pourrait monter Ă  8000tr .
Messagepar toto491 » Jeu 20 FĂ©v 2014 08:36
Moi a 9000 tout va bien :icon_mrgreen: Attention que l'aiguille est un poil optimiste sur nos nissan
Utilisateurs parcourant ce forum: Google [Bot] et 5 invités
