PràƒÂ©paration JWT (Jim Wolf Technologies) pour la NX2000
Pr?paration JWT (Jim Wolf Technologies) pour la NX2000
Messagepar Goose » Mer 22 Sep 2004 11:59
Pour ceux qui ne connaissent pas, JWT est un tr?s
gros et surtout tr?s bon pr?parateur sp?cialis? Nissan. Il a pouss? ? bout le SR20DE, et a l'ensemble des pieces les plus
fiables et les plus performantes pour le SR20DE de nos 100NX.
http://www.jimwolftechnology.com/
Voici un peu
l'ensemble des possibilit?s... (en anglais dans le texte... si vous avez besoin d'aide demandez moi).
Here
is a list of what we can do for the 1991+ Nissan Sentra SE-R/200SX/NX2000/G20/Primera/Sunny/Pulsar using the SR20DE
engine.
Note: Go to our web site and enter the part # in our products section to get more information.
ECU
upgrade $595.00 on an exchange basis. We remove the top speed limiter, raise the rev limiter to 7,700 rpm and put in the
most aggressive fuel map and timing curve for 91+ premium fuel. We also optimize the throttle response code for better
throttle response. Call for current turnaround time. (1990-97 at this time only) We do have turbo programming along with
different injector/MAF combinations available. We can reprogram your ECU for use with the SR20DE-T Bluebird and Pulsar
engines. Call us for details on this. We do offer an ECU core exchange option. The additional refundable core deposit is
$500.00 for the 1991-94 models and $700.00 for the 1995-97 models. Call us for more details. ECU upgrades for the 98+
models are still in development. Check back with us later to see how our development is progressing. It is possible to use
a 1995-97 style ECU into the 98-2001 models. Contact us for info.
PSER1-1221X Pop-Charger air intake system $159.00
(1990+)
PBREA-THER0 AIV Breather filter (for 1991-93 models,) $13.00
PSHO1-3XXX2 Pop-Charger for Ford Mustang MAF
conversion $165.00
ECU and Pop-Charger net about a 15 HP gain together
JWT NOS system (1991-97 only) is a
microprocessor controlled system (50 or 100 HP gain,) that works with the JWT ECU (you must have a JWT ECU upgrade to use
this.) The NOS Control Module actually switches the programs in the ECU between the regular upgrade and the NOS program.
NOS is only sprayed during the following conditions: Above ~ 2200 RPM and shuts off ~ 200-300 RPM below the rev limiter,
works only on full throttle depression, and with the arming switch on and bottle open. The air/fuel ratio stays at the best
optimum settings under all conditions making this system the safest and most advanced NOS system
available.
NSER1-NX136 NOS Control module 91-94 SER 50HP $450.00 (this unit gets installed inside a JWT upgraded
ECU)
NSER5-NX136 NOS Control module 95-97 SER 50HP $450.00 (this unit gets installed inside a JWT upgraded
ECU)
NSER1-NX152 NOS Control module 91-94 SER 100HP $450.00 (this unit gets installed inside a JWT upgraded ECU, must use
with 370cc injectors)
NSER5-NX152 NOS Control module 95-97 SER 100HP $450.00 (this unit gets installed inside a JWT
upgraded ECU, must use with 370cc injectors)
N4N20-HWARE NOS Hardware kit $583.00 (NOS bottle, bracket, braided hose,
NOS spray nozzle, solenoid, relay, wiring and additional plumbing and instructions.) 370cc injectors (1995 300ZX-TT,) are
required to be installed to use the 100 shot system. These injectors are available from JWT for $120.00 each or can be
purchased from a Nissan dealer.
XSER1-HEADR 91-99 SR20DE FWD header $495.00
XSE00-HEADR 00-01 SR20DE FWD header
$450.00
This header is a "Tri-Y design" and had 4-2-1 primaries and a flex pipe at the bottom. This header has a bright
finish ceramic coating (looks like polished aluminum.) This header has fittings for the EGR, AIV if needed and 02 sensor.
Horsepower gain is about 12-15 HP.
LSER1-NP000 JWT SR20DE FWD H/P pressure plate $225.00
LSER1-NDSTD
Factory style disc for use with above pressure plate is $78.00
LSER1-T0000 SR20DE throw out bearing
$30.00
LSER1-NC1MD JWT H/P pressure plate for SR20DE FWD including one side metal disc (sold as a matching set only,)
$395 (This plate/disc combination is used for those who are very aggressive with their clutch use such as drag racing and
with high horsepower turbo set-ups but still drive on the street.)
LSER1-ND2MD JWT clutch disc with metal both sides
$240.00 (use with JWT H/P pressure plate, recommended for race application and big HP turbo.)
LSER1-NF000 Aluminum
flywheel $425.00 (For the FWD SR20DE engines.) This unit is 11 lbs and allows the engine to rev much quicker resulting in
faster 0-60 and 1/4 mile times.
LSER1-TWIND JWT twin disc clutch/flywheel package, includes a unique pressure plate
with twin discs set-up and a special lightweight aluminum flywheel. Use this set-up for the very high HP turbo cars that
will be subjected to harder launching than the typical street car. The price for this set-up is $1495.00.
ASER1-990S3
SR20 S3 billet cam set, .442" lift, 260 degrees duration (1991-99 only) $560.00 set
ASER1-990S4 SR20 S4 billet cam set,
.464" lift, 266 degrees duration (1991-99 only) $560.00 set
ASER1-000S5 SR20 S5 billet cam set, .503" lift, 281 degrees
duration (1991-99 only,) use with oem springs/retainers, 7700 rpm, road race cam, lopey idle, ~8 more hp than S4, will not
pass smog, low bottom end power, use with big collector header and 3" exhaust system w/low back pressure. $560.00
set
ASER0-2KS3R SR20 S3R billet cam set, .450" lift, 262 degrees duration (for the roller rocker" 2000-2001 SR20DE)
$560.00 set
ASRRL-SPRNG Spring, HD for roller rocker SR20 engine only, SR20DE uses a roller cam in 2000-01, Allows
7,500 rev limit (stock spring=6,800 rpm,) with JWT ASER0-SKS3R cams. $17.00 each
ASRVE-SPRNG SR20VE high rev valve
spring, inner/outer pair, allows the SR20VE to rev to 8,000 rpm. Also for high lift secondary lobe cams, not for use on
SR20DE. $25.00 each
ASER1-C10C1 JWT C1 billet cam set $560.00, .476" lift, 264 degrees duration. These billet cams
require use of the JWT HD valve spring and titanium retainer set as well as a different ECU program to properly use
these.
ASER1-C20C2 JWT C2 billet cam set $560.00, ..500" lift, 275 degrees duration. These billet cams require use of the
JWT HD valve spring and titanium retainer set as well as a different ECU program to properly use these.
ASER1-C30C3 JWT C3
billet cam set $560.00, .526" lift, 285 degrees duration. These billet cams require use of the JWT HD valve spring and
ASER1-00C6M JWT C6 billet cam set $560.00,
?" lift, ? degrees duration, pro road race, 9,000 rpm max, hi comp. 11:1+, race fuel, lopey idle, no low speed driveability,
not smog compliant, use with custom larger header, can make 200hp to the wheels. Note: Must gut out OEM hydraulic lifter and
put shims back in to recommended JWT lash spec.
ASER1-SPRTI Spring/Titanium retainer set for SR20DE for JWT Pro Cams
$499.00 set
ASR20-SPROC SR20 8 hole cam sprocket set $140.00 (use with our cams for turbo applications or special
circumstances.)
ASER1-GDET7 Valve guide set, bronze, exhaust on SR20DE-T only w/7mm std O.D. valve stem size, set of 8
qty (Note: SR20DE-T Silvia/180SX/Pulsar/Bluebird/Avenir all use a larger 7mm valve stem size,) $50.00
ASER1-GUIDEX Valve
guide set, bronze, exhaust on SR20DE w/6mm std O.D. valve stem size, set of 8 qty $50.00
ASER1-GUIDIN Valve guide set,
bronze, intake on SR20DE(T) w/6mm std O.D. valve stem size, set of 8 qty $50.00
IZ325-T0370 370cc injector $131.00
each, for direct install into original OEM fuel rail (not pulsar,) use for turbo applications for 260hp max potential or JWT
100 shot N2O system.
IMSD0-50LBS 50lb MSD injector $100.00 each (use for turbo applications along with the custom fuel
rail and Ford Cobra MAF and special ECU programming.)
IMSD0-72LBS 72lb MSD injector $100.00 each (must be used with
dropping resistors,) (these are for the highest HP turbo applications and require the JWT ECU program and Ford
MAF.)
IMSD0-96LBS 96lb MSD injector $100.00 each (must use with dropping resistors,) (these are for the upcoming JWT
ECU program to use with the 1993 Ford Mustang Cobra MAF.
IRES6-6OHMS Dropping resistors for 72lb MSD injector $3.00
each
IRAIL-MSSR1 Billet fuel rail, 91-93 SER to MSD $225.00 (for use with 50lb MSD injectors)
IRAIL-MSSR2 Billet
fuel rail, 94+ SER to MSD $225.00 (for use with 50lb MSD injectors)
IMAFC-COBRA Ford Mustang Cobra MAF w/harness
adapter $325.00 (for use with larger injectors for turbo applications and requires ECU program change to
use.)
IMAFL-LT90M Ford Lightning MAF w/harness adapter, 90mm ID, 100mm OD outlet, 700hp $275.00
JWT Forged
Pistons for turbo applications $180.00 each. These pistons fit the stock rods or our billet rods below and come with pins
and double Spirolox clips. The ring grooves are cut for the 90+ 300ZX-TT piston rings. Bore sizes are 87.00mm (SZ320-T0008)
and 87.50mm (SZ320-T5008) and compression ratio is 8.5:1. The wrist pin is offset in the piston for less clatter and the
hi-silicon content of these pistons requires less clearance than conventional forged pistons. We also have an 86mm bore size
available (SSR20-T0085) if your engine does not require boring. The ring set (SSR20-R862K) for these is $83.00.
The
JWT 2.4 liter stroker kit can fit all SR20DE(T) engines. Special machining work is required to install the sleeve kit. This
set-up comes with a billet chromalloy," full counter balanced crankshaft, 4 sleeves, 4 forged hi-silicon 89.5mm pistons
(either 8.5:1 C.R. for turbo or 11:1 C.R. for N/A,) and our optional billet chromalloy" rods. The stroke is 94.4mm. The
pistons have a full floating wrist pin with double spirolox." This entire set-up is $4459.00 with our optional connecting
rods.
OSR20-STD00 "Chromalloy" Billet steel connecting rods for the SR20DE and DE-T are $200.00
each.
OSR24-CRANK SR stroker crank, 94.4mm stroke, billet chromalloy," hollow rod journals, fully counterbalanced
$2350.00
SSR20-SLEEV sleeve kit SR20, 89/90mm bore, 88.5mm ID X 95mm OD w/top flange $589.00
JWT offers
cylinder boring for SR20DE engines using our pistons and our torque plate for $200.00 labor.
JWT also can install
piston oil cooler jets into your SR20DE block (similar to the DE-T engines,) for $250.00 parts and labor.
We also
offer cylinder head machining work package. This consists of porting the intake and exhaust ports and cleaning up the
combustion chamber, match porting the intake manifold to the head and doing a multi-angle performance valve job. This is
done on your cylinder head and any additional parts are extra. Contact us for any other questions about our machine work
above. $950.00 for head package (HSR20-CHEAD) and this is on your good cylinder head/intake manifold.
OSR20-OILPU
SR20DE High volume oil pump conversion kit $295.00, 70%+ volume (includes cover, pump, pulley, spacer 91-97 SR20,) Note: Must
use with correct oil pick-up tube.
OSR20-PUPT1 Oil pick-up tube $25.00, 91-99 SR20 US Spec, use w/JWT Hi-Vol pump kit,
slight mod needed
OSR20-PUPT2 Oil pick-up tube $25.00, 00-01 SR20 US Spec, use w/JWT Hi-Vol pump kit
OSR20-PUPT3 Oil
pick-up tube $25.00, BB/N14 DET 4WD pan, (same as JDM Pulsar Tube) use for JWT Hi-Vol kit
OSR20-WPULL SR20DE (FWD)
water pump pulley, 120mm diameter, larger O.D. for lower water pump speed $39.95
The JWT 2.4 liter stroker kit can fit
all SR20DE(T) engines. Special machining work is required to install the sleeve kit. This set-up comes with a billet
chromalloy," full counter balanced crankshaft, 4 sleeves, 4 forged hi-silicon 89.5mm pistons (either 8.5:1 C.R. for turbo or
11:1 C.R. for N/A,) and our optional billet chromalloy" rods. The stroke is 94.4mm. The pistons have a full floating wrist
pin with double spirolox." This entire set-up is $4459.00 with our optional connecting rods.
GSR20-H9012 metal head
gasket SR20 FWD (90mm x 1.2mm) use when bore size will exceed factory gasket bore size. $300.00
MSER1-10000 JWT motor
mount kit fits 91-99 SR20 FWD (not G20,) the 3 round mounts have a solid, high durometer rubber inside the shell and comes
with a new custom torque strap. The 3 round mounts must be pressed into your existing engine mount brackets and replace the
original insert. Use these for all performance applications as the original mounts allow too much engine movement which
leads to cracking transmission case and wheel hop. $250.00 for the complete set.
MISCW-STKR1 JWT windshield banner
available in white only $22.00
MISCL-FRAME JWT license plate frame $4.00
MISCL-PATCH Patch, JWT embroidered, 5"
x 2", iron on or sew on $5.00
MCM10-NOMAX CM-100 Engine monitor without max, can show duty cycle, MAF voltage, MPH,
H2O in F. $119.00
MCMX1-WMAX0 CMX-100 Engine monitor with max, can show duty cycle, MAF voltage, MPH, H2O in F.
$159.00
JWT does offer 5 different turbocharger units (turbo only,) which can be used as upgrades to an existing turbo
engine or added to your custom manifold. See our web site for some info these or give us a call.
For suspension
upgrades contact Dave Turner Motorsports (858) 571-3811 or see http://www.daveturner.com
For 1995-98 SE-R owners and some
91+, Turbonetics currently sells turbo systems and uses JWT ECU and injector upgrades with them. They can be reached at
(805) 581-0333 or see http://www.turboneticsinc.com
Note: prices subject to change after 9/04 without notice, call to confirm
all pricing.
If you have any technical questions or would like to order these parts, please give us a call M-F 8-5
(pst) @ 619-442-0680
Président de l'association Japan Car
http://www.japancar.fr/
GooseNix : 100NX 2.0l 1993 - Kayaba UltraSR, H&R -35mm, BAR Ractive, Ligne full inox 2.5" VRS Exhaust, Silencieux Magnaflow 4", Cold Air Intake "home made", Collecteur HotShot, Apex'i S-Afc, Avance allumage +17°, Faisceau NGK Premium & bougies iridium, Jantes Suzuka Gold 15", Embrayage renforcé ACT Clutch, Volant moteur allegé Fidanza
Membre V.I.P.Goose
Messagepar warrior » Mer 22 Sep 2004 12:01
ah ?a c'est cool goose merci bien
pour ces info
pourquoi sur le site ya des truc sur le chien???ou la chasse au coyote?
Messagepar p0lux » Mer 22 Sep 2004 12:25
Mais dit moi,
c'est violent tt ca :icon_eek:
[Suprem NX-POWER]p0lux
Messagepar TriadeOne » Mer 22 Sep 2004 13:33
JWT c'est
vraiment le ma?tre de la pr?pa Nissan aux USA...
NX vendue...
[Suprem NX-POWER+]TriadeOne
Voiture: 100NX GTI
Messagepar Didier G » Mer 22 Sep 2004 15:00
ben en tout cas ?a donne envie...
Allez M'sieu mon banquier, un petit geste s'il vous plait, c'est bient?t Noel....
Messagepar 100nx_power » Jeu 23 Sep 2004 13:30
Clair, tr?s all?chant :cool:
[Suprem NX-POWER]100nx_power
Messagepar Franky » Jeu 23 Sep 2004 13:56
?a pousse ? faire des
folies :fou9: :icon_biggrin:
[Suprem NX-POWER+]Franky
Voiture: 100nx GTI BlackMagic
Messagepar Didier G » Jeu 23 Sep 2004 14:25
http://www.se-r.net/about/nx2000/
c'est moins spectaculaire :icon_neutral: mais c'est une NX :icon_razz:
Messagepar warrior » Jeu 23 Sep 2004 19:58
j'ai pas tout compris sur le site :icon_sad:
Messagepar 100nx_power » Ven 24 Sep 2004 07:46
warrior a écrit:j'ai pas tout compris sur le site
:icon_sad:
A vrai dire moi non plus, je ne vois pas vraiment le rapport avec le post de Goose
:icon_neutral:
Messagepar warrior » Ven 24 Sep 2004 08:02
ben faite faut trouver ou sont les pieces
perf dessus c'est pour ?a que j'ai po compris
Messagepar 100nx_power » Ven 24 Sep 2004 08:11
warrior a écrit:ben faite faut trouver ou sont les pieces perf dessus c'est pour ?a que j'ai po
compris
J'ai cherch? j'en ai pas vu, il y a qu'un doc sur une NX am?lior? !!!
:icon_confused:
Messagepar Franky » Ven 24 Sep 2004 08:51
c'est une des
premi?res pages internet sur la nx que j'avais trouv? il y a quelques ann?es :icon_mrgreen: Merci Didier ! LOL
c'est
l'intention qui compte ... :icon_biggrin:
