NXPOWER - Forum 100NX - Tuning 100NX - Mécanique 100NX - Annonces 100NX - Photos 100NXNXPOWER : forum dédié à la Nissan 100NX NX rear rotor size and caliper part numberModérateurs: carbunx, TriadeOne, Modérateurs
2 messages
• Page 1 sur 1
NX rear rotor size and caliper part numberYou guys with 2.0's, what size rotors did your car come standard with and what was the part number? I am looking for the 258mm NX rotors, but they only and produce 237x7 rears here.
-http://images.cardomain.com/member_images/12/web/504000-504999/504392_16_full.jpg
91-NX2000 97-Maxima Moderator-http://nissannx.info
I know there are 2 sizes, but I dont know which one fit on us or Eu NX.
Do you have the Nissan Fast soft ? if yes, just enter your Vin code, it will give you all the parts numbers you want. An then, you can watch in the Service manual, at SDS service date specifications, all the data you need are in too. But take care, between differents nx nationality part look like the same, but aren't in reality !! Energy/prothane motor mounts,Sabelt steering wheel, Sparco steering hub, ngk wire set, ngk platinium spark plugs, BMC intake, Brembo OEM rotors, ATE Racing 280 brake fluid, Lucas brakes pads,new paint, Aftermarket exhaust Header, RM springs soon ...
2 messages
• Page 1 sur 1
Retourner vers Chassis / Tenue de route Qui est en ligneUtilisateurs parcourant ce forum: Aucun utilisateur enregistré et 2 invités |
