Prepa d'un sr20de
Prepa d'un sr20de
Messagepar toto491 » Ven 31 Déc 2010 12:20
Je vous met un lien sur un post trés complet de nos amis amerlocs sur sr20-forum.com
http://www.sr20-forum.com/all-motor/24290-sr20de-dyno-power-write-up.html
Vous avez chaque dyno en fonction de chaque modif .
en gros avec ligne(heeader catback mufler) , cai , AAC s3 JWT, Ecu JWT , flywheel il monte a 145cv contre 120 stock :icon_twisted:
Pk des valeurs basse alors que le sr20 fait 143 cv par chez nous ? tout simplement que c'est la puissance aux roues ! compter environ 15% de perte.
CAD que son moteur sort un poil moins de 170 chevaux pour 2500$ de prepa :icon_mrgreen:
Si j'ai loupé un truc hésitez pas a corriger je suis pas un pro de l'anglais !
J'attend vos réactions , et j'économise deja pour ma part :icon_mrgreen:
Edit si je me trompe pas le moter a 260 000 km :icon_ptdr:
Edit2 la sentra SER fait 140cv stock .
Ok guys here is a thread that will anwser most of if not all of your questions on popular bolt-ons for the SR20DE motor. Please try not to cloud this thread up with you should of done this or that. i did all of these on purpose with this specific inteniton of sharing my findings. if you have questions please dont hesitate to ask pm me and ill post it in the thead
Mac
First off this is a 1991 Sentra SER with roughly 169XXX miles. AC is still in and will be removed at a later date.
Modifacations in the thread include:
Aem Cold air intake
Ebay 2.5" header
Obx test pipe
Jim Wolf Technology S3 cams
JWT ecu tune
HKS Sport Exhaust
9lbs. Flywheel
Base line power
the 119 and 120hp pulls where in 4th
the 102 was in 4th with the ac on. i aways wondered what the Hp drop was with the ac on. now i know.
INTAKE
Here is the dyno with the AEM Cai installed. i used the my 119whp run as an overlay cause it doesnt have the dip the 120whp does and is more realisticly the accurate pull.
Most of you will laugh at the fact that i made almost 4whp over stock. but as you can see there is more to the gains then peak HP. and im sure that a few of you know that power band is more important then peak hp.
You can see in the graph that from 3300rpm to 5000rpms i am making more HP then on the stock pull. but from 5k rpms to 5.7k rpms i am making the same as stock. from 5.7k rpms to redline i am making much more then i was stock. in some parts around10-12whp more. also my peak hp is moved to almost 6.5krpms. about 300rpm later then stock. torque is almost not changed at all. this is a good thing and a bad thing but does not effect the feel of the car at all.
the over all feel of the car now is very smooth in the top end and feels much better. i can feel the car pull more but i am very aware that there is some mental aspect to that.
Exhaust
Here is the dyno with the hks exhaust and i must say i am very impressed with the findings. much better then i expected. in this its my base, Intake Installed, and intake and exhaust installed you can see the top end gained a very good amount of power as much as 20whp over stock. cant wait to get headers and see the gains. the exhaust is to quiet so im going to be installing a test pipe. well see if any gains are produced
JWT S3 CAMS, JWT ECU, AND TEST PIPE
Installed the JWT S3 cams and test pipe. i was very inpressed with the gains. the torque is unbeliveable. the intake exhaust run is the last dyno i had.Now the cam run is very impressive with the amount of torque it is making. you can also see that the line is much smoother then the blue run. this is due to a new cap , rotor and wires. the parts are not new but they are nissan where my car had cheap aftermarket set on them, so they are new to the car. the s3 cams with JWT ECU run is not bad at all raising the HP and TQ all through the power band. well some would take that flash as a waste of money but the car did make more power and idles much smoother now then it did with out it. the drivablity is also better with it.
HEADER
heres the dyno with a ebay header and a 2.5" outlet. The Blue Run is the header installed and the Red Run is the last run i did see above for more info on that run. the headers were a great complement to the whole setup i have going right now. you can see that every part of the rpm range has a gain, not one spot does not. the peak is only 7whp which is more then i was expecting. this doesnt exactly mean if you put just a header on it will provide this kind of HP i think with the cams intake ect they are a good compliment for it all.
FLYWHEEL
dyno with the flywheel only made 2whp and 2wtq at peak but like all the other mods its is through out the power band. the engine revs much smoother and faster. rev match is like breathing its super easy.
i installed my factory cat and looks like i lost alot of power through out. sucks but now i dont have any buzz in the exhaust anymore.
une petite liste de pièces avec tarifs chez JWT
Here is a list of what we can do for the 1991+ Nissan Sentra SE-R/200SX/NX2000/G20/Primera/Sunny/Pulsar using the SR20DE engine.
Note: Go to our web site and enter the part # in our products section to get more information.
ECU upgrade $595.00 on an exchange basis. We remove the top speed limiter, raise the rev limiter to 7,700 rpm and put in the most aggressive fuel map and timing curve for 91+ premium fuel. We also optimize the throttle response code for better throttle response. Call for current turnaround time. (1990-97 at this time only) We do have turbo programming along with different injector/MAF combinations available. We can reprogram your ECU for use with the SR20DE-T Bluebird and Pulsar engines. Call us for details on this. We do offer an ECU core exchange option. The additional refundable core deposit is $500.00 for the 1991-94 models and $700.00 for the 1995-97 models. Call us for more details. ECU upgrades for the 98+ models are still in development. Check back with us later to see how our development is progressing. It is possible to use a 1995-97 style ECU into the 98-2001 models. Contact us for info.
PSER1-1221X Pop-Charger air intake system $159.00 (1991-99)
PBREA-THER0 AIV Breather filter (for 1991-93 models,) $13.00
PSER0-1XC61 Pop-Charger air intake system $159.00 (2000-2002)
ECU and Pop-Charger net about a 15 HP gain together
JWT NOS system (1991-97 only) is a microprocessor controlled system (50 or 100 HP gain,) that works with the JWT ECU (you must have a JWT ECU upgrade to use this.) The NOS Control Module actually switches the programs in the ECU between the regular upgrade and the NOS program. NOS is only sprayed during the following conditions: Above ~ 2200 RPM and shuts off ~ 200-300 RPM below the rev limiter, works only on full throttle depression, and with the arming switch on and bottle open. The air/fuel ratio stays at the best optimum settings under all conditions making this system the safest and most advanced NOS system available.
NSER1-NX136 NOS Control module 91-94 SER 50HP $450.00 (this unit gets installed inside a JWT upgraded ECU)
NSER5-NX136 NOS Control module 95-97 SER 50HP $450.00 (this unit gets installed inside a JWT upgraded ECU)
NSER1-NX152 NOS Control module 91-94 SER 100HP $450.00 (this unit gets installed inside a JWT upgraded ECU, must use with 370cc injectors)
NSER5-NX152 NOS Control module 95-97 SER 100HP $450.00 (this unit gets installed inside a JWT upgraded ECU, must use with 370cc injectors)
N4N20-HWARE NOS Hardware kit (call for parts list as we no longer sell this hardware) (NOS bottle, bracket, braided hose, NOS spray nozzle, solenoid, relay, wiring and additional plumbing and instructions.) 370cc injectors (1995 300ZX-TT,) are required to be installed to use the 100 shot system. These injectors are available from JWT for $137.55 each or can be purchased from a Nissan dealer.
LSER1-NP000 JWT SR20DE FWD H/P pressure plate $225.00
LSER1-NDSTD Factory style disc for use with above pressure plate is $78.00
LSER1-T0000 SR20DE throw out bearing $30.00
LSER1-ND2MD JWT clutch disc with metal both sides $240.00 (use with JWT H/P pressure plate, recommended for race application and big HP turbo.)
LSER1-NF000 Aluminum flywheel $425.00 (For the FWD SR20DE engines.) This unit is 9 lbs and allows the engine to rev much quicker resulting in faster 0-60 and 1/4 mile times.
ASER1-990S3 SR20 S3 billet cam set, .442" lift, 260 degrees duration (1991-99 only) $560.00 set
ASER1-990S4 SR20 S4 billet cam set, .464" lift, 266 degrees duration (1991-99 only) $560.00 set
Note: JWT S3 and S4 camshafts are designed to be used with OEM factory spec valve springs and retainers.
ASER1-000S5 SR20 S5 billet cam set, .503" lift, 281 degrees duration (1991-99 only,) use with oem springs/retainers, 7700 rpm, road race cam, lopey idle, ~8 more hp than S4, will not pass smog, low bottom end power, use with big collector header and 3" exhaust system w/low back pressure.
ASER0-2KS3R SR20 S3R billet cam set, .450" lift, 262 degrees duration (for the "roller rocker" 2000-2001 SR20DE) $560.00 set
ASER1-C10C1 JWT C1 billet cam set $560.00, .476" lift, 264 degrees duration. These billet cams require use of the JWT HD valve spring set as well as a different ECU program to properly use these.
ASER1-C20C2 JWT C2 billet cam set $560.00, .500" lift, 275 degrees duration. These billet cams require use of the JWT HD valve spring set as well as a different ECU program to properly use these.
ASER1-C30C3 JWT C3 billet cam set $560.00, .526" lift, 285 degrees duration. These billet cams require use of the JWT HD valve spring set as well as a different ECU program to properly use these.
ASER1-00C6M JWT C6 billet cam set $560.00, .538" lift, 314 degrees duration, pro road race, 9,000 rpm max, hi comp. 11:1+, race fuel, lopey idle, no low speed driveability, not smog compliant, use with custom larger header, can make 200hp to the wheels. Note: Must gut out OEM hydraulic lifter and put shims back in to recommended JWT lash spec.
ASER1-SPRNG Spring set for SR20DE(T) for JWT Pro Cams (optional on JWT S3, S4, S5 cams) $399.00 set
ASR20-SPROC SR20 8 hole cam sprocket set $140.00 (use with our cams for turbo applications or special circumstances.)
ASER1-GDET7 Valve guide set, bronze, exhaust on SR20DE-T only w/7mm std O.D. valve stem size, set of 8 qty (Note: SR20DE-T Silvia/180SX/Pulsar/Bluebird/Avenir all use a larger 7mm valve stem size,) $50.00
ASER1-GUIDEX Valve guide set, bronze, exhaust on SR20DE w/6mm std O.D. valve stem size, set of 8 qty $50.00
ASER1-GUIDIN Valve guide set, bronze, intake on SR20DE(T) w/6mm std O.D. valve stem size, set of 8 qty $50.00
IZ325-T0370 370cc injector $137.55 each, for direct install into original OEM fuel rail (not pulsar,) use for turbo applications for 260hp max potential or JWT 100 shot N2O system.
IMSD0-50LBS 50lb MSD injectors $100.00 each (use for turbo applications along with the custom fuel rail and Z32 type MAF or 93 Cobra MAF and special ECU programming.)
IMSD0-72LBS 72lb MSD injectors $100.00 each (must be used with dropping resistors,) (these are for the highest HP turbo applications and require the JWT ECU program and Z32 type MAF or 93 Cobra MAF.)
IMSD0-96LBS 96lb MSD injector $100.00 each (must use with dropping resistors,) (these are for the upcoming JWT ECU program to use with the Ford Lightning MAF.
IRES6-6OHMS Dropping resistors for 72lb/96lb MSD injector $3.00 each
IZ325-55500 555cc NISMO Injector $185.00 each
IZ325-74000 740cc NISMO Injector $185.00 each
IRAIL-MSSR1 Billet fuel rail, 91-93 SER to MSD $136.50 (for use with MSD injectors)
IRAIL-MSSR2 Billet fuel rail, 94+ SER to MSD $136.50 (for use with MSD injectors)
IMAFC-COBRA 1993 Ford Mustang Cobra MAF sensor with harness adapter, 350hp-520hp $325.00
IMAFL-LT90M Ford Lightning MAF w/harness adapter, 90mm ID, 100mm OD outlet, 700hp $275.00
MISCW-STKR1 JWT windshield banner available in white only $22.00
MISCL-FRAME JWT license plate frame $4.00
MISCL-PATCH Patch, JWT embroidered, 5" x 2", iron on or sew on $5.00
carement couple Fidanza + Embrayage stage 1 livré = 600€ ...
Pour info sur les flywheel
Pour fidanza il existe 2 modèles donc le 108 et 109 dents :
143201 = 109 tooth
143621 = 108 tooth
108 densts = sr20de
et 109 dents pour voiture avec OBDII et pas de crank sensor
Re: Prepa d'un sr20de
Messagepar matmax » Ven 31 Déc 2010 13:39
tres interessant !
Messagepar raph » Ven 31 Déc 2010 17:18
donc une 1.6l 102ch fait 80 et quelques chevaux au roues , quelle m...
et le 2L ne fait "que" 120ch :icon_evil:
cela dit tres interressant
apres je pense que ça s applique au sr20 quelque soit le matos ( ex : une ligne qu elle soit ssauto ou autre , mise a part la qualité du matos , c est kif kif ) non ?
ps : y en avait un sur un autre forum de nissan( :icon_rolleyes: ) qui avait passé sa nx au banc et il delivrais 116ch si je me souviens bien !
donc il deboitais presque autant qu une 2L ?!
Messagepar antoinezgz » Ven 31 Déc 2010 19:20
Oui, Jul a sa petite 1.0006l un peu prepa, et elle a l'air de marcher pas mal du tout...
Messagepar crousti » Sam 1 Jan 2011 13:43
les 116 cv de jul n etait pas au roue , mais au moteur
15% de pertes sa parait beaucoup (pour certain) mais c est ceux que je met quand je fait les test dynolicious et malgres tous c est pas optimiste
17 % pour l Tchou-Tchou qui est equiper d un torsen
20 % pour les traction
25% voir + pour les 4 RM
bon bien sur c est du a peu près car par exemple je pense que d une nx 2.0l a une 1.6 l il y a une difference de part la taille des roue , leur poid idem pour les cardan ect
[Suprem NX-POWER+]crousti
Voiture: DC2 AX 220 sdi
Messagepar Julien » Sam 1 Jan 2011 18:38
toto491 a écrit:Edit2 la sentra SER fait 140cv stock .
Aux US ou en Europe ?
Parce qu'aux USA, ils mesure la puissance des auto selon la norme SAE (qui doit vouloir dire "society of american engenieers" ou un truc du genre) alors que chez nous on par le chevaux DIN (Deutsches Institut für Normun).
La norme SAE mesure la puissance brute du moteur (sans les accessoires, genre alternateur...) alors que la puissance DIN tient compte des accessoires, est est donc plus proche de la realité.
[NX-POWER]Julien
Messagepar toto491 » Sam 1 Jan 2011 18:57
Alors la julien tu m'en demande bcp ! je ne saurais te dire pour cette différence DIN/SAE faut se renseigner !
Après pour le pourcentage de perte , c’est variable effectivement , ca reste flou , normalement au passage au banc il laisse la voiture redescendre tranquillement pour calculer ses pertes .
Messagepar raph » Sam 1 Jan 2011 19:00
toto491 a écrit:Alors la julien tu m'en demande bcp ! je ne saurais te dire pour cette différence DIN/SAE faut se renseigner !
donc en faite meme entre deux nx 2L, il peut y avoir une difference de pourcentage ?
Messagepar crousti » Sam 1 Jan 2011 19:11
très faible mais oui
Messagepar toto491 » Sam 1 Jan 2011 19:18
on pourrait presque pousser le truc en disant que tu perds plus avec une huile de boite crade et épaisse par exemple :icon_mrgreen: enfin bon pour 0.1% on va pas se prendre la tète .
Messagepar raph » Sam 1 Jan 2011 20:16
toto491 a écrit:on pourrait presque pousser le truc en disant que tu perds plus avec une huile de boite crade et épaisse par exemple :icon_mrgreen: enfin bon pour 0.1% on va pas se prendre la tète .
:lol: tu pousse le bouchon un peu loin morice
non mais comme les roulements , ou rien que l entretien du vehicule ...
Messagepar matmax » Dim 2 Jan 2011 11:50
bah c'est sur qu'il y auras forcement un difference entre 2 NX pas identique !!
meme deja entre 2 nx stock , il peut y avoir une difference !!
Messagepar Denrée » Ven 14 Jan 2011 20:40
En gros, il me manque:
l'ECU JWT (je me suis déjà renseigné auparavant, c'est pas super cher), environ 300$ sur ebay
un volant moteur alléger
Et après, j'ai au moins la même puissant que le mec, au moins car j'ai les aac JWT S4 moi.
[NX-POWER]Denrée
Messagepar toto491 » Ven 14 Jan 2011 21:40
moi je commande tout ca dans l'année VMA+embrayage prévu pour cet été et Abre a cam et gestion l'hiver prochain !
Messagepar raph » Sam 15 Jan 2011 08:29
ça vas envoyer du gros , je vois :enaccord8:
